[postgis-tickets] [PostGIS] #3332: PostGIS 2.x doesn't allow to store some invalid polygon kinds
PostGIS trac at osgeo.org
Tue Nov 17 04:13:53 PST 2015
  Reporter:  fcaa       |      Owner:  strk
      Type:  defect     |     Status:  new
  Priority:  high       |  Milestone:  PostGIS 2.2.1
 Component:  liblwgeom  |    Version:  2.2.x
Resolution:             |   Keywords:  invalid geometry
Comment (by fcaa):
 Hi:
 I've attached a sample of the invalid geometries, as SHP and as a
 SQLite/SpatiaLite database.
 My use case is the following:
 1.- The geometries are stored in a SQLite/SpatiaLite database.
 2.- The geometries are read using SpatiaLite's ST_AsBinary() function
 (used 4.3.0a version, with LWGeom 2.1.7 and GEOS 3.5.0-CAPI-1.9.0 r4084).
 3.- The geometries are inserted using PostGis's ST_GeomFromWkb() function.
 The former steps work seamlessly with PostGIS 1.5, but not with PostGIS
 2.x.
 In the meantime, I've tried to reproduce it using PostGIS Shapefile Loader
 2.2 and the SHP attached, and with a SQL script generated with ogr2ogr,
 but the geometries were loaded as expected. So, at this time I'm
 suspecting also of an issue with SpatiaLite's ST_AsBinary().
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3332#comment:8>
