[postgis-tickets] r14414 - minor cleanup and add that have binaries for 9.5beta2 32-bit
Regina Obe lr at pcorp.us
Sat Nov 21 21:22:49 PST 2015
Author: robe
Date: 2015-11-21 21:22:49 -0800 (Sat, 21 Nov 2015)
New Revision: 14414
   web/_content/pages/windows_downloads.html
Modified: web/_content/pages/windows_downloads.html
--- web/_content/pages/windows_downloads.html	2015-11-22 04:58:08 UTC (rev 14413)
+++ web/_content/pages/windows_downloads.html	2015-11-22 05:22:49 UTC (rev 14414)
@@ -17,8 +17,8 @@
 PostgreSQL 9.5beta2 (64-bit) (rereleased November 21st 2015 recompiled against 9.5beta2), 9.4 (32/64-bit), 9.3 (64-bit,32-bit) 2.2.0 is now available on application stackbuilder. The 9.5beta1 32-bits will be coming soon.
-*** If you installed PostGIS 2.2.0 for PostgreSQL 9.5beta1 (the one with a -1.exe at end), you may want to reinstall particularly if you use OGRFDW or SFCGAL.
-The PostgreSQL 9.5beta1 PostGIS bundle OGRFDW is incompatible with PostgreSQL 9.5beta2 and the SFCGAL bundled with the release (-2.exe) is a bit newer SFCGAL 1.2.2 ***
+**If you installed PostGIS 2.2.0 for PostgreSQL 9.5beta1 (the one with a -1.exe at end), you may want to reinstall particularly if you use OGRFDW or SFCGAL.
+The PostgreSQL 9.5beta1 PostGIS bundle OGRFDW is incompatible with PostgreSQL 9.5beta2 and the SFCGAL bundled with the release (-2.exe) is a bit newer SFCGAL 1.2.2**
 PostGIS 2.2.0 bundle includes:
@@ -92,10 +92,10 @@
 , we'd suggest using the companion [PostgreSQL EDB binaries-only][8] binaries which don't require installation.
 Setup is detailed in [Starting PostgreSQL in windows without install](http://www.postgresonline.com/journal/archives/172-Starting-PostgreSQL-in-windows-without-install.html).
-**PostgreSQL EDB 9.4 will not work with Windows XP, so if you have Windows XP, use PostgreSQL 9.3**
+**PostgreSQL EDB 9.4+ will not work with Windows XP, so if you have Windows XP, use PostgreSQL 9.3**
 # Windows: Winnie Bot PostGIS and pgRouting Experimental Builds
- * [for PostgreSQL 9.5beta2 64-bit][12] compiled against PostgreSQL 9.5beta2 for PostGIS 2.2, 2.3 (built with SFCGAL support) (also pgrouting 2.1)
+ * [for PostgreSQL 9.5beta2 32-bit/64-bit][12] compiled against PostgreSQL 9.5beta2 for PostGIS 2.2, 2.3 (built with SFCGAL support) (also pgrouting 2.1)
     (osm2pgrouting 2.1), (in extras folder: ``pointcloud`` )
  * [for PostgreSQL 9.4 32-bit, 64-bit][9] compiled against PostgreSQL 9.4 for PostGIS 2.2, 2.3 (built with SFCGAL support) (also pgrouting 2.0, 2.1)
