[postgis-tickets] r14423 - Add TopoGeom_{add, rem}Element functions
Sandro Santilli strk at keybit.net
Wed Nov 25 10:20:47 PST 2015
Author: strk
Date: 2015-11-25 10:20:47 -0800 (Wed, 25 Nov 2015)
New Revision: 14423
Added:
   trunk/topology/sql/topogeometry/topogeom_edit.sql.in
   trunk/topology/test/regress/topogeom_edit.sql
   trunk/topology/test/regress/topogeom_edit_expected
   trunk/NEWS
   trunk/doc/extras_topology.xml
   trunk/topology/Makefile.in
   trunk/topology/test/Makefile.in
   trunk/topology/topology.sql.in
Add TopoGeom_{add,rem}Element functions
Includes regression tests and documentation
Modified: trunk/NEWS
--- trunk/NEWS	2015-11-25 18:02:44 UTC (rev 14422)
+++ trunk/NEWS	2015-11-25 18:20:47 UTC (rev 14423)
@@ -5,6 +5,8 @@
  * Deprecated signatures *
  * New Features *
+  - TopoGeom_addElement, TopoGeom_remElement (Sando Santilli)
 PostGIS 2.2.0
 2015/10/07
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml	2015-11-25 18:02:44 UTC (rev 14422)
+++ trunk/doc/extras_topology.xml	2015-11-25 18:20:47 UTC (rev 14423)
@@ -185,7 +185,9 @@
                 <para>
                   <xref linkend="GetTopoGeomElements"/>,
                   <xref linkend="topoelementarray" />,
-                  <xref linkend="topogeometry" />
+                  <xref linkend="topogeometry" />,
+                  <xref linkend="TopoGeom_addElement" />,
+                  <xref linkend="TopoGeom_remElement" />
                 </para>
             </refsection>
 		</refentry>
@@ -2939,6 +2941,97 @@
 			</refsection>
 		</refentry>
+    <refentry id="TopoGeom_addElement">
+			<refnamediv>
+				<refname>TopoGeom_addElement</refname>
+				<refpurpose>Add an element to the definition of a TopoGeometry</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+					<funcdef>topogeometry <function>TopoGeom_addElement</function></funcdef>
+					<paramdef><type>topogeometry </type> <parameter>tg</parameter></paramdef>
+          <paramdef><type>topoelement </type> <parameter>el</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Adds a <xref linkend="topoelement" /> to the definition of a
+TopoGeometry object. Does not error out if the element is already
+part of the definition.
+                </para>
+                <!-- use this format if new function -->
+                <para>Availability: 2.3</para>
+			</refsection>
+			<refsection>
+				<title>Examples</title>
+        <programlisting>
+-- Add edge 5 to TopoGeometry tg
+UPDATE mylayer SET tg = TopoGeom_addElement(tg, '{5,2}');
+				</programlisting>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+        <para>
+<xref linkend="TopoGeom_remElement" />,
+<xref linkend="CreateTopoGeom" />
+        </para>
+			</refsection>
+		</refentry>
+    <refentry id="TopoGeom_remElement">
+			<refnamediv>
+				<refname>TopoGeom_remElement</refname>
+				<refpurpose>Remove an element from the definition of a TopoGeometry</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+					<funcdef>topogeometry <function>TopoGeom_remElement</function></funcdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <para>
+Removes a <xref linkend="topoelement" /> from the definition of a
+                </para>
+			</refsection>
+			<refsection>
+        <programlisting>
+-- Remove face 43 from TopoGeometry tg
+UPDATE mylayer SET tg = TopoGeom_remElement(tg, '{43,3}');
+				</programlisting>
+			</refsection>
+			<refsection>
+        <para>
+<xref linkend="TopoGeom_addElement" />,
+        </para>
+			</refsection>
+		</refentry>
     <refentry id="toTopoGeom_editor_proxy">
 			<refnamediv>
         <refname>toTopoGeom</refname>
@@ -3037,7 +3130,7 @@
                 <para>tg_id is the topogeometry id of the topogeometry object in the topology in the layer denoted by <varname>layer_id</varname> in the topology.layer table.</para>
-                <para>Availability: 1.?</para>
+                <para>Availability: 2.0.0</para>
 			</refsection>
@@ -3050,7 +3143,12 @@
 			<refsection>
-				<para><xref linkend="GetTopoGeomElementArray"/>, <xref linkend="topoelement"/></para>
+				<para>
+          <xref linkend="GetTopoGeomElementArray"/>,
+          <xref linkend="topoelement"/>,
+        </para>
 			</refsection>
 		</refentry>
Modified: trunk/topology/Makefile.in
--- trunk/topology/Makefile.in	2015-11-25 18:02:44 UTC (rev 14422)
+++ trunk/topology/Makefile.in	2015-11-25 18:20:47 UTC (rev 14423)
@@ -100,7 +100,29 @@
 topology_upgrade.sql: topology_drop_before.sql topology_upgrade.sql.in topology_drop_after.sql
 	cat $^ > $@
-topology.sql: sql/sqlmm.sql.in sql/populate.sql.in sql/polygonize.sql.in sql/export/gml.sql.in sql/export/TopoJSON.sql.in sql/query/getnodebypoint.sql.in sql/query/getedgebypoint.sql.in sql/query/getfacebypoint.sql.in sql/query/GetRingEdges.sql.in sql/query/GetNodeEdges.sql.in sql/manage/TopologySummary.sql.in sql/manage/CopyTopology.sql.in sql/manage/ManageHelper.sql.in sql/topoelement/topoelement_agg.sql.in sql/topogeometry/type.sql.in sql/topogeometry/totopogeom.sql.in sql/topogeometry/cleartopogeom.sql.in sql/topogeometry/simplify.sql.in sql/predicates.sql.in ../postgis/sqldefines.h ../postgis_svn_revision.h
+topology.sql: \
+	sql/sqlmm.sql.in \
+	sql/populate.sql.in \
+	sql/polygonize.sql.in \
+	sql/export/gml.sql.in \
+	sql/export/TopoJSON.sql.in \
+	sql/query/getnodebypoint.sql.in \
+	sql/query/getedgebypoint.sql.in \
+	sql/query/getfacebypoint.sql.in \
+	sql/query/GetRingEdges.sql.in \
+	sql/query/GetNodeEdges.sql.in \
+	sql/manage/TopologySummary.sql.in \
+	sql/manage/CopyTopology.sql.in \
+	sql/manage/ManageHelper.sql.in \
+	sql/topoelement/topoelement_agg.sql.in \
+	sql/topogeometry/type.sql.in \
+	sql/topogeometry/totopogeom.sql.in \
+	sql/topogeometry/cleartopogeom.sql.in \
+	sql/topogeometry/topogeom_edit.sql.in \
+	sql/topogeometry/simplify.sql.in \
+	sql/predicates.sql.in \
+	../postgis/sqldefines.h \
+	../postgis_svn_revision.h
 uninstall_topology.sql: topology.sql ../utils/create_undef.pl
 	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
Added: trunk/topology/sql/topogeometry/topogeom_edit.sql.in
--- trunk/topology/sql/topogeometry/topogeom_edit.sql.in	                        (rev 0)
+++ trunk/topology/sql/topogeometry/topogeom_edit.sql.in	2015-11-25 18:20:47 UTC (rev 14423)
@@ -0,0 +1,95 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2015 Sandro Santilli <strk at keybit.net>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+/* #define POSTGIS_TOPOLOGY_DEBUG 1 */
+--  Add an element to a TopoGeometry definition
+CREATE OR REPLACE FUNCTION topology.TopoGeom_addElement(tg topology.TopoGeometry, el topology.TopoElement)
+  RETURNS topology.TopoGeometry
+AS
+DECLARE
+  toponame TEXT;
+  sql TEXT;
+BEGIN
+  -- Get topology name
+  BEGIN
+    SELECT name
+    FROM topology.topology
+      INTO STRICT toponame WHERE id = topology_id(tg);
+  EXCEPTION
+    WHEN NO_DATA_FOUND THEN
+      RAISE EXCEPTION 'No topology with name "%" in topology.topology',
+        atopology;
+  END;
+  -- Insert new element
+  sql := format('INSERT INTO %s.relation'
+         '(topogeo_id,layer_id,element_id,element_type)'
+         ' VALUES($1,$2,$3,$4)', quote_ident(toponame));
+  BEGIN
+    EXECUTE sql USING id(tg), layer_id(tg), el[1], el[2];
+  EXCEPTION
+    WHEN unique_violation THEN
+      -- already present, let go
+    WHEN OTHERS THEN
+      RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE;
+  END;
+  RETURN tg;
+END
+LANGUAGE 'plpgsql' VOLATILE STRICT;
+--  Remove an element from a TopoGeometry definition
+CREATE OR REPLACE FUNCTION topology.TopoGeom_remElement(tg topology.TopoGeometry, el topology.TopoElement)
+AS
+DECLARE
+  toponame TEXT;
+  sql TEXT;
+BEGIN
+  BEGIN
+    SELECT name
+  EXCEPTION
+        atopology;
+  END;
+  -- Delete the element
+  sql := format('DELETE FROM %s.relation WHERE '
+         'topogeo_id = $1 AND layer_id = $2 AND '
+         'element_id = $3 AND element_type = $4',
+         quote_ident(toponame));
+  RETURN tg;
+END
Modified: trunk/topology/test/Makefile.in
--- trunk/topology/test/Makefile.in	2015-11-25 18:02:44 UTC (rev 14422)
+++ trunk/topology/test/Makefile.in	2015-11-25 18:20:47 UTC (rev 14423)
@@ -51,6 +51,7 @@
 	regress/topogeo_addlinestring.sql \
 	regress/topogeo_addpoint.sql \
 	regress/topogeo_addpolygon.sql \
+  regress/topogeom_edit.sql \
 	regress/topogeometry_type.sql \
 	regress/topojson.sql \
   regress/topologysummary.sql \
Added: trunk/topology/test/regress/topogeom_edit.sql
--- trunk/topology/test/regress/topogeom_edit.sql	                        (rev 0)
+++ trunk/topology/test/regress/topogeom_edit.sql	2015-11-25 18:20:47 UTC (rev 14423)
@@ -0,0 +1,24 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+select 'create', createtopology('tt') > 0;
+-- Create a line layer (will be layer 1)
+CREATE TABLE tt.f_line(id serial);
+SELECT 'simple_line_layer', AddTopoGeometryColumn('tt', 'tt', 'f_line','g','LINE');
+INSERT INTO tt.f_line (g) VALUES
+ ( toTopoGeom('LINESTRING(0 0, 10 0)'::geometry, 'tt', 1) );
+ ( toTopoGeom('LINESTRING(10 0, 30 0)'::geometry, 'tt', 1) );
+-- Sane calls
+SELECT id, 'start', id, ST_Length(g) FROM tt.f_line WHERE id = 1;
+SELECT id, 'add',  id, ST_Length(TopoGeom_addElement(g, '{2,2}')) FROM tt.f_line WHERE id = 1;
+SELECT id, 'rem',  id, ST_Length(TopoGeom_remElement(g, '{1,2}')) FROM tt.f_line WHERE id = 1;
+SELECT id, 'dup',  id, ST_Length(TopoGeom_addElement(g, '{2,2}')) FROM tt.f_line WHERE id = 1;
+SELECT id, 'mis',  id, ST_Length(TopoGeom_remElement(g, '{1,2}')) FROM tt.f_line WHERE id = 1;
+DROP TABLE tt.f_line;
+select droptopology('tt');
Added: trunk/topology/test/regress/topogeom_edit_expected
--- trunk/topology/test/regress/topogeom_edit_expected	                        (rev 0)
+++ trunk/topology/test/regress/topogeom_edit_expected	2015-11-25 18:20:47 UTC (rev 14423)
@@ -0,0 +1,8 @@
+create|t
+simple_line_layer|1
+1|start|1|10
+1|add|1|30
+1|rem|1|20
+1|dup|1|20
+1|mis|1|20
+Topology 'tt' dropped
Modified: trunk/topology/topology.sql.in
--- trunk/topology/topology.sql.in	2015-11-25 18:02:44 UTC (rev 14422)
+++ trunk/topology/topology.sql.in	2015-11-25 18:20:47 UTC (rev 14423)
@@ -1993,6 +1993,7 @@
 #include "sql/topogeometry/cleartopogeom.sql.in"
 #include "sql/topogeometry/simplify.sql.in"
 #include "sql/topogeometry/totopogeom.sql.in"
+#include "sql/topogeometry/topogeom_edit.sql.in"
 --  Exports
 #include "sql/export/gml.sql.in"
