[postgis-tickets] r14438 - Reduce paranoia in ST_MakeValid
Sandro Santilli strk at keybit.net
Thu Nov 26 05:00:22 PST 2015
Author: strk
Date: 2015-11-26 05:00:21 -0800 (Thu, 26 Nov 2015)
New Revision: 14438
   trunk/liblwgeom/lwgeom_geos_clean.c
Modified: trunk/liblwgeom/lwgeom_geos_clean.c
--- trunk/liblwgeom/lwgeom_geos_clean.c	2015-11-26 09:15:07 UTC (rev 14437)
+++ trunk/liblwgeom/lwgeom_geos_clean.c	2015-11-26 13:00:21 UTC (rev 14438)
@@ -44,6 +44,7 @@
 #include <assert.h>
 /* #define POSTGIS_DEBUG_LEVEL 4 */
+/* #define PARANOIA_LEVEL 2 */
 #undef LWGEOM_PROFILE_MAKEVALID
@@ -951,6 +952,7 @@
+#if PARANOIA_LEVEL > 1
 	 * Now check if every point of input is also found
 	 * in output, or abort by returning NULL
@@ -958,10 +960,6 @@
 	 * Input geometry was lwgeom_in
-		const int paranoia = 2;
-		/* TODO: check if the result is valid */
-		if (paranoia)
 			int loss;
 			GEOSGeometry *pi, *po, *pd;
@@ -981,8 +979,8 @@
 				lwnotice("Vertices lost in LWGEOM_GEOS_makeValid");
 				/* return NULL */
+#endif /* PARANOIA_LEVEL > 1 */
 	return gout;
