[postgis-tickets] [PostGIS] #3380: "geometry crosses edge" with 1e-2 tolerance
PostGIS trac at osgeo.org
Fri Nov 27 01:33:46 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.0.8
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 Further reduction of the case, 3 lines of 3 vertices each:
   SELECT DropTopology( 'shp_error' );
   SELECT CreateTopology( 'shp_error', 0, 0.01);
   SELECT TopoGeo_AddLinestring('shp_error', '
   LINESTRING(
   1612829.90652844007126987 4841274.48807844985276461,
   1612830.1566380700096488 4841287.23833953030407429,
   1612883.15799825009889901 4841277.73794914968311787)
   ', 0);
   LINESTRING(
   1612790.88055733009241521 4841286.88526585046201944,
   1612830.15823523001745343 4841287.12674008030444384,
   1612829.98813172010704875 4841274.56198261026293039)
   ', 0);
    LINESTRING(
   1612830.15823523 4841287.12674008,
   1612881.64990281 4841274.56198261,
   1612883.09421571 4841223.09636279)
   ', 0);
 The third line has an endpointi incident to node 8 in the figure above
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3380#comment:4>
