[postgis-tickets] [PostGIS] #3380: "geometry crosses edge" with 1e-2 tolerance
PostGIS trac at osgeo.org
Fri Nov 27 01:39:57 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.0.8
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 Adding the cyan line to the existing topology triggers the error.
 The distance from the new edge endpoint and the existing node is half the
 tolerance.
 [[Image(failling.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3380#comment:5>
