[postgis-tickets] [PostGIS] #2603: [raster] Add docs for ST_MapAlgebra with mask parameter
trac at osgeo.org
Sat Oct 3 10:10:07 PDT 2015
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: new
Priority: critical | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
dustymugs if you are around, I'm working on adding this to docs. I presume
this is new in 2.2.0 (so flagging it as such). Can you explain what the
mask does? From example in rt_mapalgebra_mast.sql -- looks like the mask
is a matrix of some sort which I am guessing only gets applied to the
neighborhood of pixels to set pixels as nodata.
So I'm guessing it does similar to :
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=selectmask
(I apologize now for linking to competitor documentation :) )
If I don't hear back from you before Paul pulls the switch, I'll just
document the protos and be very vague about what it does not to embarrass
myself.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2603#comment:2>
