[postgis-tickets] [PostGIS] #2603: [raster] Add docs for ST_MapAlgebra with mask parameter
PostGIS trac at osgeo.org
Sat Oct 3 11:30:38 PDT 2015
  Reporter:  dustymugs  |      Owner:  dustymugs
      Type:  task       |     Status:  new
  Priority:  critical   |  Milestone:  PostGIS 2.2.0
 Component:  raster     |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 I'm guessing it does similar to ST_Clip except instead of passing in a
 geometry you pass in a matrix?
 Anway committed first attempt at r14178.  I'm not sure what weighted arg
 does either.  I'll try to come up with a visual example before Paul pulls
 the trigger.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2603#comment:4>
