[postgis-tickets] [PostGIS] #3298: ST_3DClosestPoint, ST_3DLongestLine, ST_3DMaxDistance regression between 2.1.8 and 2.2.0rc1
PostGIS trac at osgeo.org
Sat Oct 3 12:12:57 PDT 2015
2.1.8 and 2.2.0rc1
  Reporter:  robe     |      Owner:  nicklas
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by nicklas):
 Ok, this is a little scary.
 When dealing with mixed dimensionality in #2034 I put check to not let
 multi-geometries through.
 But now I cannot see the problem to just let them go through. It seems to
 work as expected, and I have an idea about why I was afraid of it.
 But I think and hope that I was wrong then because not that check is
 removed.
 Please test this. What it is about is different combinations of
 multi/multi, multi/single in ST_3DClosestPoint and ST_3DShortestLine
 The problem is that it is so hard to verify if the answer is right more
 than in the most simple examples.
 commit in r14179
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3298#comment:7>
