[postgis-tickets] [PostGIS] #3298: ST_3DClosestPoint, ST_3DLongestLine, ST_3DMaxDistance regression between 2.1.8 and 2.2.0rc1
PostGIS trac at osgeo.org
Sun Oct 4 01:35:12 PDT 2015
2.1.8 and 2.2.0rc1
  Reporter:  robe     |      Owner:  nicklas
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by robe):
 Yah I was thinking about that.  There is no good z to use.  I think the
 only thing we could do is return same answer as 2D (whic is what you are
 doing) or return an error (which assumes the user accidentally used 3D
 functon when they wanted 2D).  I would just leave it as is.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3298#comment:11>
