[postgis-tickets] [PostGIS] #2603: [raster] Add docs for ST_MapAlgebra with mask parameter
PostGIS trac at osgeo.org
Sun Oct 4 13:52:32 PDT 2015
  Reporter:  dustymugs  |      Owner:  dustymugs
      Type:  task       |     Status:  new
  Priority:  critical   |  Milestone:  PostGIS 2.2.0
 Component:  raster     |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 dustymugs: seems you have hard-coded somewhere a neighborhood of 1 for
 mask as I can't input distance x and y.  Yet I can't find where that is.
 So if I understand correctly, then the mask should always be a 3x3 matrix
 as it stands.  I'm also not sure what you mean by pull the neighborhood.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2603#comment:7>
