[postgis-tickets] [PostGIS] #3314: Regression tests fail on big endian architectures
PostGIS trac at osgeo.org
Mon Oct 5 07:41:43 PDT 2015
  Reporter:  sebastic               |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 pramsey at a quick glance, looks like raster tests usually avoid
 outputting the raster probably for this reason.
 What I can do is rewrite the tests to do dump out the raster as an array
 using ST_DumpValues.  Since I'm working in this area anyway not too much
 trouble.  Is that okay with you.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3314#comment:8>
