[postgis-tickets] [PostGIS] #3316: ST_Reverse documentation should mention no support for M values
PostGIS trac at osgeo.org
Mon Oct 5 11:43:57 PDT 2015
  Reporter:  pauldzy        |      Owner:  robe
      Type:  enhancement    |     Status:  new
  Priority:  low            |  Milestone:  PostGIS 2.1.9
 Component:  documentation  |    Version:  2.1.x
Resolution:                 |   Keywords:  ST_Reverse
Comment (by robe):
 ah yes even in my 2.1.8
 POSTGIS="2.1.8 r13780" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER
 (and the sT_AsText) returns the ogc preferred.
 SELECT ST_ASText(ST_Reverse('LINESTRING M(0 0 0, 1 1 1)'::geometry));
          st_astext
  LINESTRING M (1 1 1,0 0 0)
 (1 row)
 Paul,
 Can you provide the
 SELECT postgis_full_version();
 you are seeing the issue and also which particular query you are running
 where you are not seeing your M come back?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3316#comment:3>
