[postgis-tickets] [PostGIS] #3320: Compiler warnings in lwgeom_topo.c
PostGIS trac at osgeo.org
Wed Oct 7 05:36:01 PDT 2015
 Reporter:  dbaston  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 2.2.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I'm haven't worked w/this functionality, so these may be irrelevant, but
 it seemed that No. 1 and 2 were not.
 line 1382: parameter "ref" is never used
 lines 3504 and 3516: if conditions check if variable does not equal itself
 (span_pre.nextCCW != span_pre.nextCCW)
 line 4975: variable mindist is used but never initialized (I realize
 current usage is safe)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3320>
