[postgis-tickets] [PostGIS] #3321: Performance regression in topology load
PostGIS trac at osgeo.org
Wed Oct 7 10:44:52 PDT 2015
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 2.2.0
Component:  topology  |    Version:  trunk
 Keywords:            |
 I've tried loading some of the polygons from the famous (?)
 'million_poly_topo1' dataset which was shared some time ago on the mailing
 list:
 https://lists.osgeo.org/pipermail/postgis-devel/2014-January/024085.html
 What I found is that trunk (2.2.0dev) is slower at loading them than 2.1
 branch. I'm still trying to figure out why.
 If you want to move this to a different milestone please use 2.2.1 (not
 available right now)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3321>
