[postgis-tickets] [PostGIS] #3323: tickets failing on 2.3 cause we are using deprecated calls
PostGIS trac at osgeo.org
Wed Oct 7 14:40:38 PDT 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.5w64/test_84_diff)
 --- tickets_expected    2015-10-07 14:03:41.000000000 -0700
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.5w64/test_84_out
 2015-10-07 14:33:44.000000000 -0700
 @@ -8,6 +8,7 @@
  #58|220187|150406|220289|150507
  ERROR:  lwgeom_to_gml2: 'CurvePolygon' geometry type not supported
  #66|CIRCULARSTRING(0 0,1 1,2 2)
 +WARNING:  ST_Shift_Longitude signature was deprecated in 2.2.0. Please
 use ST_ShiftLongitude
  #68a|MULTIPOINT(1 3,4 5)
  ERROR:  lwgeom_longitude_shift: unsupported geom type: CircularString
  #69|CIRCULARSTRING(220269 150417,220228 150507,220228 150408)
 @@ -96,6 +97,7 @@
  #835.12|MULTIPOLYGON EMPTY
  #650|MULTIPOINT(0 0,1 1,2 2)
  #667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30
 40))
 +WARNING:  ST_Distance_Spheroid signature was deprecated in 2.2.0. Please
 use ST_DistanceSpheroid
  #677.deprecated|1121395
  #677|1121395
  #680|01d107000000000000000024c000000000000049400000000000000040
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3323>
