[postgis-tickets] [PostGIS] #3329: Topology population regression
PostGIS trac at osgeo.org
Sat Oct 10 09:42:38 PDT 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.2.1
 Component:  topology  |    Version:  2.2.x
Resolution:            |   Keywords:
Comment (by strk):
 Changing the min tolerance computation to use this method (halving
 tolerance while still good) changes behaviour with some of the cases in
 regress/topogeo_addlinestring, but doesn't introduce any load failure
 there. I think it would make sense to get "min tolerance" correctly,
 somehow (still a research matter)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3329#comment:10>
