[postgis-tickets] [PostGIS] #3338: postgis extension that returns not supported for all Raster functions if raster not available
PostGIS trac at osgeo.org
Sun Oct 18 02:54:03 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.0.x
Resolution:           |   Keywords:
Old description:
> Was talking on IRC with astrodog and it seems they are having a hard time
> getting raster in the FreeBSD packages because of all the dependencies
> GDAL brings in which a user may not have.
> The easiest option which he proposed which I think we can swing is to
> still have a PostGIS extension that zeros out raster if not available.
> Just returns a not supported note similar to what we do with ST_GeoJSON
> and several GEOS functions if your GEOS is not new enough.
> Here is bit of IRC dialog for context
> 23:39] <astrodog> We build gdal as another package, with pretty broad
> support for formats.
> [23:39] <astrodog> That way things just work for people.
> [23:39] <robe2> and disable everything except some key ones like sqlite,
> odbc, curl
> [23:40] <robe2> I even disable postgres
> [23:40] <astrodog> But PostGIS brings in GDAL, which brings in a pile of
> other things.
> [23:40] <astrodog> None of it is bad if you build from source... it's the
> binary packages that cause problems.
> [23:41] <robe2> one more reason not to have a shared liblwgeom :)
> [23:41] <robe2> astrodog: so you can't build an isolated gdal sits in
> postgres bin?
> [23:42] <robe2> on windows always searches in postgres bin first
> [23:42] <robe2> so I can override system dlls by replacing with my own
> version
> [23:42] <robe2> not sure how it works on unix/linux
> [23:43] <astrodog> robe: If you guys bundle it, I can. If you don't, I'm
> expected to use whatever the gdal port does, that way users can set
> whatever gdal options they want.
> [23:43] <robe2> so if we included gdal source as part of our dist
> package?
> [23:45] <robe2> pl/v8 (not sure if they still do have to check) included
> v8 source zip as part of theres
> [23:45] <astrodog> Sure. Then it's just some thing you guys included...
> and any issues it creates would be sent up to PostGIS trac. *grin*
> [23:45] <robe2> cause the v8 upstream was kinda flaky (I mean you hit a
> bad version and you are screwed)
> [23:48] <robe2> astrodog: so if you have gdal already is the issue
> because depending on user installing, they might have a different gdal
> with not all the dependencies available
> [23:49] <robe2> I got the impression from listening to devrimgunduz that
> was his pain
> [23:49] <robe2> and why EL 5, CentOS 5 he was very apologetic for
> [23:49] <astrodog> Yeah.
> [23:49] <astrodog> For us... we install GDAL with a huge pile of things,
> so that the various bits that depend on it can all use one version.
> [23:50] <astrodog> But it means requiring GDAL is a fairly large
> requirement.
> [23:50] <robe2> I wonder how hard it would be to get GDAL to do run-time
> load like they do with proj already
> [23:50] <robe2> that seems like the fundamental issue
> [23:51] <robe2> astrodog: do you built spatialite and rasterlite
> [23:51] <robe2> as I recall rasterlite relies on gdal I think
> [23:51] <robe2> so would have similar issue
> [23:52] <astrodog> Yeah, it does.
> [23:52] <robe2> so you have same issue with it?
> [23:53] <astrodog> Yeah, but with rasterlite, people know they're in for
> it.
> [23:53] <robe2> one thing I always wanted was for people to be able to
> swap out the gdal I have with a beefier one
> [23:53] <astrodog> The issue we run into with PostGIS is that the SQL
> method isn't as well documented... so we get PRs saying "Loading the
> extension doesn't work!"
> [23:54] <robe2> well we could document that better I guess
> [23:54] <robe2> I didn't like it cause it required too much explaining
> [23:54] <astrodog> It's not so much you guys, as every tutorial on the
> planet skips over that option. :P
> [23:54] <robe2> like find where your files are stored -- and I lost 90%
> of the audience at that point
> [23:54] <astrodog> Be nice if the extension had a way to tell if it had
> raster support or not, and act accordingly.
> [23:55] <robe2> and had to digress into if you are on this - its' here ,
> if you are on that it's here etc
> [23:55] <astrodog> *nod*
> [23:56] <robe2> yah but then it wouldn't be the same extension
> [23:56] <robe2> we could create a postgis_no_raster extension
> [23:56] <astrodog> Could the extension stub out the raster bits if they
> aren't there?
> [23:57] <astrodog> So the function exists, it just always returns not
> supported.
> [23:57] <astrodog> :P
> [23:57] <robe2> but the problem is the extension model doesn't have a way
> to say something like requires: postgis or postgis_no_raster;
> [23:57] <robe2> So you'd have issues with like you can't install
> postgis_sfcgal, pgrouting etc.
> [23:57] <robe2> astrodog: ah didn't think about that
> [23:57] <robe2> yah it could
> [23:57] <robe2> that's a great idea
> [23:58] <robe2> we do that already for some functons like json and geos
> if you are running a lower geos
> [23:58] <robe2> I'll ticket it
New description:
 Was
 broad support for formats.
 sqlite, odbc, curl
 pile of other things.
 it's the binary packages that cause problems.
  in postgres bin?
  own version
 don't, I'm expected to use whatever the gdal port does, that way users
 can set whatever gdal options they want.
 package?
 included v8 source zip as part of theres
 included... and any issues it creates would be sent up to PostGIS trac.
 *grin*
 hit a bad version and you are screwed)
 devrimgunduz that was his pain
 things, so that the various bits that depend on it can all use one
 version.
 requirement.
 run-time load like they do with proj already
 in for it.
 able to swap out the gdal I have with a beefier one
 SQL method isn't as well documented... so we get PRs saying "Loading the
 explaining
  the planet skips over that option. :P
 lost 90% of the audience at that point
 it had raster support or not, and act accordingly.
 here , if you are on that it's here etc
  they aren't there?
 not supported.
 have a way to say something like requires: postgis or postgis_no_raster;
  geos if you are running a lower geos
Comment (by strk):
 I thought we had a ticket for this but could not find one.
 My idea was that we should have these extensions:
  - postgis_core
  - postgis_raster depends on postgis_core
  - postgis_topology depends on postgis_core
  - postgis_sfcgal depends on postgis_core
  - (postgis depends on postgis_core and postgis_raster) for backward
 compatibility
 How to get there is still to be found out, especially when it comes to
 upgrading an existing system.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3338#comment:1>
