[postgis-tickets] r14300 - minor updates to setup learned by resetting up new debbie
Regina Obe lr at pcorp.us
Thu Oct 22 00:52:35 PDT 2015
Author: robe
Date: 2015-10-22 00:52:35 -0700 (Thu, 22 Oct 2015)
New Revision: 14300
   buildbots/debian/jenkins_setup.txt
Modified: buildbots/debian/jenkins_setup.txt
--- buildbots/debian/jenkins_setup.txt	2015-10-22 06:11:25 UTC (rev 14299)
+++ buildbots/debian/jenkins_setup.txt	2015-10-22 07:52:35 UTC (rev 14300)
@@ -2,6 +2,7 @@
 On 64-bit Debian 6
 su root
 apt-get update
+apt-get upgrade #install latest patches
 wget -q -O - http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key | apt-key add -
 Add to: /etc/apt/sources.list
@@ -11,36 +12,63 @@
 escape
 :w
 ## latest version of jenkins requires JDK 7 and one that came with debian is JDK6
 ## java -version (if not JDK 7 or higher)
 sudo su -
 echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu precise main" | tee -a /etc/apt/sources.list
 echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu precise main" | tee -a /etc/apt/sources.list
+#to get newer proj 4.9.1 needed to do this
+echo "deb http://ftp.us.debian.org/debian sid main" | tee -a /etc/apt/sources.list
+apt-get update
+apt-get install libproj9 libproj-dev proj-bin proj-data
+apt-get install g++
+apt-get update
+apt-get install jenkins
+##installing java if the above fails
 apt-key adv --keyserver keyserver.ubuntu.com --recv-keys EEA14886
 apt-get update
 apt-get install oracle-java7-installer
+## end installing java
+#for building sfcgal
+echo "deb-src http://debian.mirrors.ovh.net/debian/ sid main contrib non-free" | tee -a /etc/apt/sources.list
+sudo apt-get update
+apt-get build-dep sfcgal-bin
+apt-get -b source sfcgal-bin
+apt-get install libcgal-dev libboost-all-dev libmpfr-dev libgmp-dev libopenscenegraph-dev libopenthreads-dev libpq-dev libqt4-dev libqt4-opengl-dev pkg-kde-tools
 #make it the default
 sudo apt-get install oracle-java7-set-default
+apt-get install git
-apt-get update
-apt-get install jenkins
 --to get autoconf etc --
 apt-get install autoconf libtool build-essential
 #CUnit
+apt-get install libreadline6 libreadline6-dev zlib1g-dev
 apt-get install libcunit1-dev libcunit1-doc libcunit1
 apt-get install docbook
-apt-get install libxml2-dev proj xsltproc docbook-xsl docbook-mathml gettext
-apt-get install libjson0-dev
+apt-get install libxml2-dev n xsltproc docbook-xsl docbook-mathml gettext
+apt-cache search json #see latest version
+apt-get install libjson-c-dev
 apt-get install dblatex
 apt-get install imagemagick
-apt-get install bison libreadline5-dev
+apt-get install libxml2 libxml2-dev
+apt-get install bison
 apt-get install libiconv-hook1
 apt-get install subversion
 #(for future translation work)
 apt-get install poxml
 apt-get install curl
+apt-get install python-dev
 wget https://bitbucket.org/pypa/setuptools/raw/bootstrap/ez_setup.py -O - | sudo python
 curl -O https://raw.github.com/pypa/pip/master/contrib/get-pip.py
 sudo python get-pip.py
@@ -48,9 +76,9 @@
 #for doxygen build and  graph generation
 apt-get install doxygen graphviz
-apt-get install apache2 (for displaying docbook etc.)
+apt-get install apache2  #(for displaying docbook etc.)
 apt-get install flex (needed for 1.3)
-apt-get install dbtoepub (not currently used but will be to publish documentation in epub format)
+apt-get install dbtoepub (publish documentation in epub format)
 #for building sfcgal, pointcloud
 apt-get install cmake
@@ -77,9 +105,18 @@
 Managed Script Plugin
 -- These are the additional ones I installed --
+Blame Upstream Committers
+conditional-buildstep
+Config File Provider Plugin
+GIT client plugin
+GIT plugin
 Hudson SCP publisher plugin (needed so can create a job that uploads to PostGIS website.  It makes the process the same on windows as on Linux)
 Simple Theme Plugin (for changing background and style sheet)
 Parameterized Trigger Plugin (for triggering subprojects and passing along main parameters)
+Build with Parameters
 Doxygen PlugIn
 IRC Plugin and Instant Messenger Plugin (so can broadcast to PostGIS IRC)
-Git
+Managed Scripts
+SCM API Plugin
+SVN Publisher plugin
+Text Finder Run Condition Plugin
\ No newline at end of file
