[postgis-tickets] [PostGIS] #3345: Building latest stable and developmen versions fails on multiple cores
PostGIS trac at osgeo.org
Thu Oct 22 12:33:32 PDT 2015
 Reporter:  bypasser  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 2.2.1
Component:  postgis   |    Version:  2.2.x
 Keywords:            |
 Building the the latest stable (2.2.0) and development (2.2.1dev) package
 in a clean chroot on an up to date Arch Linux system fails while the -j4
 makeflag is enabled.
 Disabling the option of multiple cores to be used to build the software
 let's the compile process finish successfully. This was not the case in
 the previous versions.
 Link to the used PKGBUILD:
 https://projects.archlinux.org/svntogit/community.git/tree/trunk/PKGBUILD?h=packages/postgis
 An "option=(!makeflags)" had to be added to compile postgis.
 v2.2.0
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
 -fno-strict-aliasing -fwrapv -fexcess-precision=standard -march=x86-64
 -mtune=generic -O2 -pipe -fstack-protector-strong -fpic -shared -o
 postgis-2.2.so postgis_module.o lwgeom_accum.o lwgeom_spheroid.o
 lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
 lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
 lwgeom_geos.o lwgeom_backend_api.o lwgeom_geos_prepared.o
 lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
 lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
 lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o
 lwgeom_dumppoints.o lwgeom_functions_lrs.o lwgeom_functions_temporal.o
 long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o
 gserialized_typmod.o gserialized_gist_2d.o gserialized_gist_nd.o
 gserialized_estimate.o geography_inout.o geography_btree.o
 geography_measurement.o geography_measurement_trees.o geometry_inout.o
 -L/usr/lib -Wl,-O1,--sort-common,--as-needed,-z,relro  -Wl,--as-needed
 -Wl,-rpath,'/usr/lib',--enable-new-dtags  ../libpgcommon/libpgcommon.a
 ../liblwgeom/.libs/liblwgeom.a  -L/usr/lib  -lgeos_c -lproj  -ljson-c
 -lxml2 -lz -lm -ldl   -Wl,--exclude-libs,ALL
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.0/postgis'
 ---- Making all in regress
 make[1]: Entering directory '/build/postgis/src/postgis-2.2.0/regress'
 make[1]: Nothing to be done for 'all'.
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.0/regress'
 ---- Making all in raster
 make[1]: Entering directory '/build/postgis/src/postgis-2.2.0/raster'
 make -C rt_core
 make -C rt_pg
 make -C loader
 make -C rt_pg rtpostgis.sql
 make[2]: Entering directory
 '/build/postgis/src/postgis-2.2.0/raster/rt_pg'
 '/build/postgis/src/postgis-2.2.0/raster/rt_core'
 gcc -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong  -fPIC
 -DPIC  -Wall -Wmissing-prototypes -I../../liblwgeom -I/usr/include
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_util.o rt_util.c
 '/build/postgis/src/postgis-2.2.0/raster/loader'
 make -C ../rt_core
 make[3]: Entering directory
 make[2]: *** No rule to make target '../rt_core/librtcore.a', needed by
 'rtpostgis.o'.  Stop.
 make[2]: Leaving directory '/build/postgis/src/postgis-2.2.0/raster/rt_pg'
 Makefile:28: recipe for target 'pglib' failed
 make[1]: *** [pglib] Error 2
 make[1]: *** Waiting for unfinished jobs....
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_spatial_relationship.o
 rt_spatial_relationship.c
 /usr/bin/cpp -traditional-cpp -w -P -I../../postgis/ -I../../
 rtpostgis.sql.in | grep -v '^#' | \
 /usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/rtpostgis-2.2'g" >
 rtpostgis.sql
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_mapalgebra.o rt_mapalgebra.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_geometry.o rt_geometry.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_statistics.o rt_statistics.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_pixel.o rt_pixel.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_warp.o rt_warp.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_band.o rt_band.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_raster.o rt_raster.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_serialize.o rt_serialize.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_wkb.o rt_wkb.c
 -I/usr/include -D_FORTIFY_SOURCE=2  -c -o rt_context.o rt_context.c
 -DPIC  -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom
 -I/usr/include -I/usr/include   -c raster2pgsql.c
 ar rs librtcore.a rt_util.o rt_spatial_relationship.o rt_mapalgebra.o
 rt_geometry.o rt_statistics.o rt_pixel.o rt_warp.o rt_band.o rt_raster.o
 rt_serialize.o rt_wkb.o rt_context.o
 ar: creating librtcore.a
 make[3]: Leaving directory
 /bin/sh ../../libtool --mode=link gcc -march=x86-64 -mtune=generic -O2
 -pipe -fstack-protector-strong  -fPIC -DPIC  -Wall -Wmissing-prototypes
 -I../rt_core -I../../liblwgeom  -I/usr/include -I/usr/include
 ../rt_core/librtcore.a raster2pgsql.o -Wl,-O1,--sort-common,--as-
 needed,-z,relro ../../liblwgeom/liblwgeom.la -L/usr/lib -lgdal  -L/usr/lib
 -lgeos_c  -lc -lm -o raster2pgsql
 libtool: link: gcc -march=x86-64 -mtune=generic -O2 -pipe -fstack-
 protector-strong -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core
 -I../../liblwgeom -I/usr/include -I/usr/include raster2pgsql.o -Wl,-O1 -Wl
 ,--sort-common -Wl,--as-needed -Wl,-z -Wl,relro -o .libs/raster2pgsql
 ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.so -L/usr/lib
 -lproj -ljson-c -lgdal -lgeos_c -lc -lm
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.0/raster'
 GNUmakefile:16: recipe for target 'all' failed
 make: *** [all] Error 1
 v2.2.1dev
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.1dev/postgis'
 make[1]: Entering directory '/build/postgis/src/postgis-2.2.1dev/regress'
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.1dev/regress'
 make[1]: Entering directory '/build/postgis/src/postgis-2.2.1dev/raster'
 make -C rt_core
 make -C rt_pg
 make -C loader
 '/build/postgis/src/postgis-2.2.1dev/raster/rt_core'
 '/build/postgis/src/postgis-2.2.1dev/raster/rt_pg'
 '/build/postgis/src/postgis-2.2.1dev/raster/loader'
 make -C ../rt_core
 rtpostgis.sql
 make[1]: Leaving directory '/build/postgis/src/postgis-2.2.1dev/raster'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3345>
