[postgis-tickets] [PostGIS] #3338: postgis extension no-raster version
PostGIS trac at osgeo.org
Sat Oct 24 11:44:40 PDT 2015
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.0.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Was
>  talking on IRC with astrodog and it seems they are having a hard time
> getting raster in the FreeBSD packages because of all the dependencies
> GDAL brings in which a user may not have.
> The easiest option which he proposed which I think we can swing is to
> still have a PostGIS extension that zeros out raster if not available.
> Just returns a not supported note similar to what we do with ST_GeoJSON
> and several GEOS functions if your GEOS is not new enough.
> Here is bit of IRC dialog for context
> 23:39] <astrodog> We build gdal as another package, with pretty
> broad support for formats.
> [23:39] <astrodog> That way things just work for people.
> [23:39] <robe2> and disable everything except some key ones like
> sqlite, odbc, curl
> [23:40] <robe2> I even disable postgres
> [23:40] <astrodog> But PostGIS brings in GDAL, which brings in a
> pile of other things.
> [23:40] <astrodog> None of it is bad if you build from source...
> it's the binary packages that cause problems.
> [23:41] <robe2> one more reason not to have a shared liblwgeom :)
> [23:41] <robe2> astrodog: so you can't build an isolated gdal sits
>  in postgres bin?
> [23:42] <robe2> on windows always searches in postgres bin first
> [23:42] <robe2> so I can override system dlls by replacing with my
>  own version
> [23:42] <robe2> not sure how it works on unix/linux
> [23:43] <astrodog> robe: If you guys bundle it, I can. If you
> don't, I'm expected to use whatever the gdal port does, that way users
> can set whatever gdal options they want.
> [23:43] <robe2> so if we included gdal source as part of our dist
> package?
> [23:45] <robe2> pl/v8 (not sure if they still do have to check)
> included v8 source zip as part of theres
> [23:45] <astrodog> Sure. Then it's just some thing you guys
> included... and any issues it creates would be sent up to PostGIS trac.
> *grin*
> [23:45] <robe2> cause the v8 upstream was kinda flaky (I mean you
> hit a bad version and you are screwed)
> [23:48] <robe2> astrodog: so if you have gdal already is the issue
>  because depending on user installing, they might have a different gdal
> with not all the dependencies available
> [23:49] <robe2> I got the impression from listening to
> devrimgunduz that was his pain
> [23:49] <robe2> and why EL 5, CentOS 5 he was very apologetic for
> [23:49] <astrodog> Yeah.
> [23:49] <astrodog> For us... we install GDAL with a huge pile of
> things, so that the various bits that depend on it can all use one
> version.
> [23:50] <astrodog> But it means requiring GDAL is a fairly large
> requirement.
> [23:50] <robe2> I wonder how hard it would be to get GDAL to do
> run-time load like they do with proj already
> [23:50] <robe2> that seems like the fundamental issue
> [23:51] <robe2> astrodog: do you built spatialite and rasterlite
> [23:51] <robe2> as I recall rasterlite relies on gdal I think
> [23:51] <robe2> so would have similar issue
> [23:52] <astrodog> Yeah, it does.
> [23:52] <robe2> so you have same issue with it?
> [23:53] <astrodog> Yeah, but with rasterlite, people know they're
> in for it.
> [23:53] <robe2> one thing I always wanted was for people to be
> able to swap out the gdal I have with a beefier one
> [23:53] <astrodog> The issue we run into with PostGIS is that the
> SQL method isn't as well documented... so we get PRs saying "Loading the
>  extension doesn't work!"
> [23:54] <robe2> well we could document that better I guess
> [23:54] <robe2> I didn't like it cause it required too much
> explaining
> [23:54] <astrodog> It's not so much you guys, as every tutorial on
>  the planet skips over that option. :P
> [23:54] <robe2> like find where your files are stored -- and I
> lost 90% of the audience at that point
> [23:54] <astrodog> Be nice if the extension had a way to tell if
> it had raster support or not, and act accordingly.
> [23:55] <robe2> and had to digress into if you are on this - its'
> here , if you are on that it's here etc
> [23:55] <astrodog> *nod*
> [23:56] <robe2> yah but then it wouldn't be the same extension
> [23:56] <robe2> we could create a postgis_no_raster extension
> [23:56] <astrodog> Could the extension stub out the raster bits if
>  they aren't there?
> [23:57] <astrodog> So the function exists, it just always returns
> not supported.
> [23:57] <astrodog> :P
> [23:57] <robe2> but the problem is the extension model doesn't
> have a way to say something like requires: postgis or postgis_no_raster;
> [23:57] <robe2> So you'd have issues with like you can't install
> postgis_sfcgal, pgrouting etc.
> [23:57] <robe2> astrodog: ah didn't think about that
> [23:57] <robe2> yah it could
> [23:57] <robe2> that's a great idea
> [23:58] <robe2> we do that already for some functons like json and
>  geos if you are running a lower geos
> [23:58] <robe2> I'll ticket it
New description:
 UPDATE - I propose keeping the extension name: still ```postgis``` and not
 zeroing out raster, but encoding the lack of raster support in the version
 rather than the extension name.  This approach takes a lot less changes
 and has the benefit of painless backward compatibility compared to other
 options proposed.
 Was
 sqlite, odbc, curl
  in postgres bin?
  own version
 package?
 *grin*
 version.
 requirement.
 in for it.
 explaining
  they aren't there?
 not supported.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3338#comment:13>
