[postgis-tickets] r14308 - up port PostGIS 2.1 branch release notes
Regina Obe lr at pcorp.us
Sat Oct 24 12:45:20 PDT 2015
Author: robe
Date: 2015-10-24 12:45:20 -0700 (Sat, 24 Oct 2015)
New Revision: 14308
   branches/2.2/NEWS
   branches/2.2/doc/release_notes.xml
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2015-10-24 19:41:20 UTC (rev 14307)
+++ branches/2.2/NEWS	2015-10-24 19:45:20 UTC (rev 14308)
@@ -161,6 +161,31 @@
     smaller files for ease of long-term maintenance and development
   - #1220, lwerror and lwnotice function became internal to liblwgeom
+PostGIS 2.1.8
+2015/07/07
+ * Bug Fixes *
+  - #3159, do not force a bbox cache on ST_Affine
+  - #3018, GROUP BY geography sometimes returns duplicate rows
+  - #3048, shp2pgsql - illegal number format when specific system locale set
+  - #3094, Malformed GeoJSON inputs crash backend
+  - #3104, st_asgml introduces random characters in ID field
+  - #3155, Remove liblwgeom.h on make uninstall
+  - #3177, gserialized_is_empty cannot handle nested empty cases
+  - Fix crash in ST_LineLocatePoint
+PostGIS 2.1.7
+2015/03/30
+ * Bug Fixes *
+  - #3086, ST_DumpValues() crashes backend on cleanup with invalid
+           band indexes
+  - #3088, Do not (re)define strcasestr in a liblwgeom.h
 PostGIS 2.1.6
 2015/03/20
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml	2015-10-24 19:41:20 UTC (rev 14307)
+++ branches/2.2/doc/release_notes.xml	2015-10-24 19:45:20 UTC (rev 14308)
@@ -81,6 +81,61 @@
     </simplesect>
 	</sect1>
+	    <sect1>
+      <title>Release 2.1.8</title>
+      <para>Release date: 2015-07-07</para>
+      <para>This is a critical bug fix release.</para>
+      <simplesect>
+        <title>Bug Fixes</title>
+        <para>#3159, do not force a bbox cache on ST_Affine</para>
+        <para>#3018, GROUP BY geography sometimes returns duplicate rows</para>
+        <para>#3048, shp2pgsql - illegal number format when specific system locale set</para>
+        <para>#3094, Malformed GeoJSON inputs crash backend</para>
+        <para>#3104, st_asgml introduces random characters in ID field</para>
+        <para>#3155, Remove liblwgeom.h on make uninstall</para>
+        <para>#3177, gserialized_is_empty cannot handle nested empty cases</para>
+        <para>Fix crash in ST_LineLocatePoint</para>
+      </simplesect>
+    </sect1>
+    <sect1>
+      <title>Release 2.1.7</title>
+      <para>Release date: 2015-03-30</para>
+      <simplesect>
+        <para>#3086, ST_DumpValues() crashes backend on cleanup with invalid band indexes</para>
+        <para>#3088, Do not (re)define strcasestr in a liblwgeom.h</para>
+      </simplesect>
+    </sect1>
+    <sect1>
+      <title>Release 2.1.6</title>
+      <para>Release date: 2015-03-20</para>
+      <para>This is a bug fix and performance improvement release.</para>
+      <simplesect>
+        <title>Enhancements</title>
+        <para>#3000, Ensure edge splitting and healing algorithms use indexes</para>
+        <para>#3048, Speed up geometry simplification (J.Santana @ CartoDB)</para>
+        <para>#3050, Speep up geometry type reading (J.Santana @ CartoDB)</para>
+      </simplesect>
+      <simplesect>
+        <para>#2941, allow geography columns with SRID other than 4326</para>
+        <para>#3069, small objects getting inappropriately fluffed up w/ boxes</para>
+        <para>#3068, Have postgis_typmod_dims return NULL for unconstrained dims</para>
+        <para>#3061, Allow duplicate points in JSON, GML, GML ST_GeomFrom* functions</para>
+        <para>#3058, Fix ND-GiST picksplit method to split on the best plane</para>
+        <para>#3052, Make operators <-> and <#> available for PostgreSQL < 9.1</para>
+        <para>#3045, Fix dimensionality confusion in &&& operator</para>
+        <para>#3016, Allow unregistering layers of corrupted topologies</para>
+        <para>#3015, Avoid exceptions from TopologySummary</para>
+        <para>#3020, ST_AddBand out-db bug where height using width value</para>
+        <para>#3031, Allow restore of Geometry(Point) tables dumped with empties in them</para>
+      </simplesect>
+    </sect1>
 	<sect1>
         <title>Release 2.1.5</title>
         <para>Release date: 2014-12-18</para>
