[postgis-tickets] r14315 - addresses #3347 force order of staged insert columns to be in table column order
Regina Obe lr at pcorp.us
Sat Oct 24 15:11:00 PDT 2015
Author: robe
Date: 2015-10-24 15:11:00 -0700 (Sat, 24 Oct 2015)
New Revision: 14315
   branches/2.2/extras/tiger_geocoder/tiger_loader_2013.sql
Modified: branches/2.2/extras/tiger_geocoder/tiger_loader_2013.sql
--- branches/2.2/extras/tiger_geocoder/tiger_loader_2013.sql	2015-10-24 22:07:51 UTC (rev 14314)
+++ branches/2.2/extras/tiger_geocoder/tiger_loader_2013.sql	2015-10-24 22:11:00 UTC (rev 14315)
@@ -373,12 +373,14 @@
 				FROM information_schema.columns
 				 WHERE table_name = param_target_table
 					AND table_schema = var_data_schema
-					AND column_name <> ALL(param_columns_exclude) ), ',') || ') SELECT '
+					AND column_name <> ALL(param_columns_exclude)
+                    ORDER BY ordinal_position ), ',') || ') SELECT '
 					|| array_to_string(ARRAY(SELECT quote_ident(column_name::text)
 				 WHERE table_name = param_staging_table
 					AND table_schema = var_staging_schema
-					AND column_name <> ALL( param_columns_exclude) ), ',') ||' FROM '
+					AND column_name <> ALL( param_columns_exclude)
+                    ORDER BY ordinal_position ), ',') ||' FROM '
 					|| var_staging_schema || '.' || param_staging_table || ';';
 	RAISE NOTICE '%', var_sql;
 	EXECUTE (var_sql);
