[postgis-tickets] [PostGIS] #3350: 2.2.0 fails to build on OS X
PostGIS trac at osgeo.org
Mon Oct 26 18:35:13 PDT 2015
 Reporter:  petere                 |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  high                   |  Milestone:  PostGIS 2.2.1
Component:  build/upgrade/install  |    Version:  2.2.x
 Keywords:                         |
 2.2.0 no longer builds on OS X:
 ld: unknown option: --exclude-libs
 This is because of the addition of the `--exclude-libs` flag, per #3281.
 The configure check should be changed from `AC_LIBTOOL_COMPILER_OPTION` to
 `AC_LIBTOOL_LINKER_OPTION`, because the compiler will happily accept the
 option and ignore it, but the linker will complain when it doesn't
 recognize it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3350>
