[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
PostGIS trac at osgeo.org
Tue Sep 1 16:58:16 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Okay on mingw after I change the debugf to
 POSTGIS_DEBUGF(2, "Datum value %g", PG_GETARG_FLOAT8(2));
 I get this:
 DEBUG:  [lwgeom_accum.c:pgis_geometry_accum_transfn:134] Datum value 1.4
 on my vc++ postgres compiled I get this which is really odd since this is
 the one giving the right answer (and yet I get a tolerance error)
 ERROR:  Tolerance not defined
 ********** Error **********
 SQL state: XX000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3220#comment:19>
