[postgis-tickets] [PostGIS] #3272: PostgreSQL 9.2 64-bit windows fails on loader/dumper
PostGIS trac at osgeo.org
Sat Sep 5 01:15:55 PDT 2015
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.2.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 I had recently added PostgreSQL 9.2 64-bit and noticed on winnie it
 consistently crashes at:
  loader/Point .. failed ( wkt test: running shp2pgsql:
 /projects/postgis/tmp/2.2.0dev_pg9.2_geos3.5.0_gdal2.0w64/loader.err)
  loader/PointM .. failed ( wkt test: running shp2pgsql:
  loader/PointZ .. failed ( wkt test: running shp2pgsql:
  loader/MultiPoint .. failed ( wkt test: running shp2pgsql:
  loader/MultiPointM .. failed ( wkt test: running shp2pgsql:
  loader/MultiPointZ .. failed ( wkt test: running shp2pgsql:
  loader/Arc .. failed ( wkt test: running shp2pgsql:
  loader/ArcM .. failed ( wkt test: running shp2pgsql:
  loader/ArcZ .. failed ( wkt test: running shp2pgsql:
  loader/Polygon .. failed ( wkt test: running shp2pgsql:
  loader/PolygonM .. failed ( wkt test: running shp2pgsql:
  loader/PolygonZ .. failed ( wkt test: running shp2pgsql:
  loader/TSTPolygon .. failed ( wkt test: running shp2pgsql:
  loader/TSIPolygon .. failed ( wkt test: running shp2pgsql:
  loader/TSTIPolygon .. failed ( wkt test: running shp2pgsql:
  loader/PointWithSchema ... failed ( wkb test: running shp2pgsql:
  loader/NoTransPoint .. failed ( wkt test: running shp2pgsql:
  loader/NotReallyMultiPoint .. failed ( wkt test: running shp2pgsql:
  loader/MultiToSinglePoint .. failed ( wkt test: running shp2pgsql:
  loader/ReprojectPts ... failed ( wkt test: running shp2pgsql:
  loader/ReprojectPtsGeog ... failed ( wkt test: running shp2pgsql:
  loader/Latin1 .. failed ( wkb test: running shp2pgsql:
  loader/Latin1-implicit .. failed ( wkb test: running shp2pgsql:
  loader/mfile .. failed ( wkb test: running shp2pgsql:
  dumper/literalsrid ... failed (dumping:
 /projects/postgis/tmp/2.2.0dev_pg9.2_geos3.5.0_gdal2.0w64/dumper-
 literalsrid.err)
  dumper/realtable ... failed (dumping:
 realtable.err)
 I haven't ruled out a configuration error on my part.
 The 32-bit 9.2 seems fine though.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3272>
