[postgis-tickets] [PostGIS] #3243: piles 'o clang warnings in topology
trac at osgeo.org
Tue Sep 8 09:59:49 PDT 2015
Reporter: pramsey | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Okay I was mistaken -- it is failing in the cberror call not the
appendinfostring calls.
So that explains why I'm only getting the warning in those since in other
places you have %d.
Like I said though the IF define is fine. The issue is your cberror would
rely on msvcrt implementation (the Postgres one needs ANSI implementation)
so we'd need two different formats to handle -- not sure its worth the
trouble.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3243#comment:16>
