[postgis-tickets] [PostGIS] #3275: ST_GeomFromGeoJsonof invalid GeoJSON with missing type crashes server process
PostGIS trac at osgeo.org
Thu Sep 10 15:53:00 PDT 2015
process
 Reporter:  pdmaseberg  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:
Component:  postgis     |    Version:  2.1.x
 Keywords:              |
 Running the following query in which the crs has a missing type that is
 empty
 SELECT ST_GeomFromGeoJson('{"type":"Point","crs"
  :{"type":""},"coordinates":[-97.3361,37.6914]}');
 Gives the output of
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 I have seen this on the following versions
 PostgreSQL 9.4.0 on x86_64-unknown-linux-gnu, compiled by gcc (GCC) 4.4.7
 20120313 (Red Hat 4.4.7-11), 64-bit POSTGIS="2.1.5 r13152"
 GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
 1.9.2, released 2012/10/08" LIBXML="2.7.6" LIBJSON="UNKNOWN" RASTER
 PostgreSQL 9.4.4 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
 4.8.2-19ubuntu1) 4.8.2, 64-bit POSTGIS="2.1.7 r13414"
 1.10.1, released 2013/08/26" LIBXML="2.9.1" LIBJSON="UNKNOWN" RASTER
 4.9.2-10ubuntu13) 4.9.2, 64-bit POSTGIS="2.1.5 r13152"
 1.11.2, released 2015/02/10" LIBXML="2.9.2" LIBJSON="UNKNOWN" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3275>
