[postgis-tickets] [PostGIS] #3275: ST_GeomFromGeoJsonof invalid GeoJSON with missing type crashes server process
PostGIS trac at osgeo.org
Fri Sep 11 18:46:03 PDT 2015
process
  Reporter:  pdmaseberg  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 2.1.9
 Component:  postgis     |    Version:  2.1.x
Resolution:  worksforme  |   Keywords:
Comment (by pdmaseberg):
 I got the latest version of libjson-c.so and used LD_PRELOAD and it still
 crashes. I did get a stack trace of the crash and attached it. I am not
 sure how I have can have the exact same version as your Ubuntu server and
 have it crash while you cannot. I guess I don't follow how your libjson is
 setup different. Anyway I will keep looking at it, just wanted to post
 that stacktrace incase it is helpfully.
 Program received signal SIGSEGV, Segmentation fault.
 strlen () at ../sysdeps/x86_64/strlen.S:106
 106     ../sysdeps/x86_64/strlen.S: No such file or directory.
 (gdb) where
 #0  strlen () at ../sysdeps/x86_64/strlen.S:106
 #1  0x00007f5a2d5bd4ff in lwgeom_from_geojson () from
 /usr/lib/liblwgeom-2.1.7.so
 #2  0x00007f5a2d8237dd in geom_from_geojson () from
 /usr/lib/postgresql/9.4/lib/postgis-2.1.so
 #3  0x00007f5a4013d933 in ExecMakeFunctionResultNoSets
 (fcache=0x7f5a419ae590, econtext=0x7f5a419aee20, isNull=0x7ffc072902dc "",
 isDone=<optimized out>)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/executor/execQual.c:2026
 #4  0x00007f5a40141e41 in ExecEvalExprSwitchContext
 (expression=expression at entry=0x7f5a419ae590, econtext=<optimized out>,
 isNull=isNull at entry=0x7ffc072902dc "", isDone=isDone at entry=0x0)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/executor/execQual.c:4360
 #5  0x00007f5a401bce0e in evaluate_expr (expr=<optimized out>,
 result_type=result_type at entry=258914,
 result_typmod=result_typmod at entry=-1,
 result_collation=result_collation at entry=0)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:4575
 #6  0x00007f5a401be852 in evaluate_function (func_tuple=0x7f5a406847a8,
 context=0x7ffc07290640, funcvariadic=0 '\000', args=0x7f5a419f8400,
 input_collid=100, result_collid=0, result_typmod=-1,
     result_type=258914, funcid=259353) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:4136
 #7  simplify_function (funcid=259353, result_type=258914,
 result_typmod=-1, result_collid=result_collid at entry=0,
 input_collid=input_collid at entry=100, args_p=args_p at entry=0x7ffc07290458,
     funcvariadic=funcvariadic at entry=0 '\000',
 process_args=process_args at entry=1 '\001',
 allow_non_const=allow_non_const at entry=1 '\001',
 context=context at entry=0x7ffc07290640)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:3775
 #8  0x00007f5a401bf8cc in eval_const_expressions_mutator
 (node=0x7f5a419f8020, context=0x7ffc07290640) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:2459
 #9  0x00007f5a401726cc in expression_tree_mutator
 (node=node at entry=0x7f5a419f8070, mutator=mutator at entry=0x7f5a401bf010
 <eval_const_expressions_mutator>, context=context at entry=0x7ffc07290640)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/nodes/nodeFuncs.c:2629
 #10 0x00007f5a401bf422 in eval_const_expressions_mutator
 (node=0x7f5a419f8070, context=0x7ffc07290640) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:3428
 #11 0x00007f5a4017233b in expression_tree_mutator
 (node=node at entry=0x7f5a419f7c48, mutator=mutator at entry=0x7f5a401bf010
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/nodes/nodeFuncs.c:2560
 #12 0x00007f5a401bf422 in eval_const_expressions_mutator
 (node=0x7f5a419f7c48, context=context at entry=0x7ffc07290640) at
 #13 0x00007f5a401c0950 in eval_const_expressions
 (root=root at entry=0x7f5a419f81a0, node=<optimized out>) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/util/clauses.c:2301
 #14 0x00007f5a401adae7 in preprocess_expression
 (root=root at entry=0x7f5a419f81a0, expr=<optimized out>, kind=kind at entry=1)
 at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/plan/planner.c:675
 #15 0x00007f5a401b12b4 in subquery_planner
 (glob=glob at entry=0x7f5a419f7a98, parse=parse at entry=0x7f5a419f7808,
 parent_root=parent_root at entry=0x0, hasRecursion=hasRecursion at entry=0
 '\000', tuple_fraction=0,
     subroot=subroot at entry=0x7ffc07290748) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/plan/planner.c:423
 #16 0x00007f5a401b18f1 in standard_planner (parse=0x7f5a419f7808,
 cursorOptions=0, boundParams=0x0) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/optimizer/plan/planner.c:210
 #17 0x00007f5a4022e9b4 in pg_plan_query (querytree=<optimized out>,
 cursorOptions=cursorOptions at entry=0, boundParams=boundParams at entry=0x0)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/tcop/postgres.c:777
 #18 0x00007f5a4022eaa4 in pg_plan_queries (querytrees=<optimized out>,
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/tcop/postgres.c:836
 #19 0x00007f5a40230d0f in exec_simple_query (query_string=0x7f5a419f68d0
 "SELECT ST_GeomFromGeoJson('{\"type\":\"Point\",\"crs\"\n
 :{\"type\":\"\"},\"coordinates\":[-97.3361,37.6914]}');")
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/tcop/postgres.c:1001
 #20 PostgresMain (argc=<optimized out>, argv=argv at entry=0x7f5a419726c0,
 dbname=0x7f5a41972560 "client_store_dev", username=<optimized out>)
     at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/tcop/postgres.c:4074
 #21 0x00007f5a4000202d in BackendRun (port=0x7f5a419b2460) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/postmaster/postmaster.c:4164
 #22 BackendStartup (port=0x7f5a419b2460) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/postmaster/postmaster.c:3829
 #23 ServerLoop () at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/postmaster/postmaster.c:1597
 #24 0x00007f5a401dc001 in PostmasterMain (argc=5, argv=<optimized out>) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/postmaster/postmaster.c:1244
 #25 0x00007f5a40002d5d in main (argc=5, argv=0x7f5a41971760) at
 /tmp/buildd/postgresql-9.4-9.4.4/build/../src/backend/main/main.c:228
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3275#comment:2>
