[postgis-tickets] [PostGIS] #3281: Avoid exporting symbols in the postgresql module
PostGIS trac at osgeo.org
Mon Sep 21 10:06:55 PDT 2015
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * type:  defect => enhancement
 * version:  1.5.X => trunk
 * resolution:   => fixed
 * milestone:  PostGIS 1.5.9 => PostGIS 2.2.0
Comment:
 Well, plan changed, I dont' feel comfortable about backporting this. Just
 in case someone is really using the symbols directly from the postgis
 module (after all that's how I initially coded the D&P simplification
 function as an external module...).
 For the future, liblwgeom might be used by more modules also dynamically.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3281#comment:5>
