[postgis-tickets] [PostGIS] #3280: Almost collinear edges prevent adding a copy of existing edge
PostGIS trac at osgeo.org
Wed Sep 23 03:57:15 PDT 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.1.9
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:  robustness
Comment (by strk):
 It's to be noted that the center vertex of the L-shaped line is so close
 to the straight line that ST_Distance returns 0, still ST_Within returns
 false:
 strk=# select ST_Distance(ST_PointN(e11.geom, 2), e10.geom) from
 bug3280.edge e11, bug3280.edge e10 where e11.edge_id = 11 and e10.edge_id
 = 10;
  st_distance
            0
 (1 row)
 strk=# select ST_Within(ST_PointN(e11.geom, 2), e10.geom) from
 = 10;
  st_within
  f
 (1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3280#comment:4>
