[postgis-tickets] [PostGIS] #3250: cu_algorithm warnings
PostGIS trac at osgeo.org
Thu Sep 24 04:52:04 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  2.1.x
Resolution:  wontfix  |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 It's a won't fix. I don't know how to address it without brutalizing the
 underlying code. (They are legitimate unsigned ints, they fit into a
 32-bit address register even, don't require 64-bit values..., I'm pretty
 sure they were originally declared as unsigned int, but got changed to
 unsigned long long to try and address just this problem. (You could
 confirm by changing them back to unsigned int to see)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3250#comment:5>
