[postgis-tickets] [PostGIS] #3299: regression ST_LineCrossingDirection used to work with CIRCULARLINESTRING?
PostGIS trac at osgeo.org
Tue Sep 29 08:18:45 PDT 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.2.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 POSTGIS="2.1.8 r13780" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER
 POSTGIS="2.2.0dev r14092" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
 LIBJSON="0.12" RASTER
 I'm not so concerned about this, cause I didn't know
 sT_LineCrossingDirection was ever supposed to work with curves, but
 evidentally in 2.1.8 it thought it did.
 SELECT ST_LineCrossingDirection('LINESTRING(-11.1111111 70,70
 -11.1111111)'::geometry,
     'CIRCULARSTRING(-71.0821 42.3036,-71.4821 42.3036,-71.7821
 42.7036,-71.0821 42.7036,-71.0821 42.3036)'::geometry)
 In 2.1.8, this returns 0
 in 2.2.0 this returns:
 ERROR:  This function only accepts LINESTRING as arguments.
 CONTEXT:  SQL function "st_linecrossingdirection" statement 1
 Fill free to dismiss as won't fix, if this was an intentional change.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3299>
