[postgis-tickets] [PostGIS] #3301: PostGIS_HasBBOX regress with 2.1.8 (intentional change?)
PostGIS trac at osgeo.org
Tue Sep 29 12:26:36 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I suspect this is intentional, but logging it as a regress just in case.
> Testing with
> POSTGIS="2.2.0dev r14136" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
> 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
> LIBJSON="0.12" (core procs from "2.2.0dev r14092" need upgrade) RASTER
> (raster procs from "2.2.0dev r14092" need upgrade)
> SELECt PostGIS_HasBBox('LINESTRING(-11 70,70 -10)'::geometry)
> In 2.1.8 this returns true, but in 2.2.0 returns false.
> Returns true for 3 point, so I am guessing this is just an optimization
> change since the box talkes as much sapce a the geometry.
New description:
 Testing with
 change since the box talkes as much space as the geometry.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3301#comment:1>
