[postgis-tickets] [PostGIS] #3303: Error on DE check-translation
PostGIS trac at osgeo.org
Tue Sep 29 14:13:53 PDT 2015
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  high       |  Milestone:  PostGIS 2.2.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 Okay I added the check_translation step
 and now I get this:
 http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.2.0_docs_translations/182/console
 Creating html for language de_DE...
 make[1]: Entering directory
 '/var/lib/jenkins/workspace/postgis/docs/branches/2.2_translations/doc/po/de_DE'
 po2xml ../../extras_address_standardizer.xml
 extras_address_standardizer.xml.po > extras_address_standardizer.xml
 po2xml ../../extras_historytable.xml extras_historytable.xml.po >
 po2xml ../../extras_tigergeocoder.xml extras_tigergeocoder.xml.po >
 po2xml ../../extras_topology.xml extras_topology.xml.po >
 extras_topology.xml
 po2xml ../../extras.xml extras.xml.po > extras.xml
 po2xml ../../faq_raster.xml faq_raster.xml.po > faq_raster.xml
 po2xml ../../faq.xml faq.xml.po > faq.xml
 po2xml ../../installation.xml installation.xml.po > installation.xml
 po2xml ../../introduction.xml introduction.xml.po > introduction.xml
 po2xml ../../performance_tips.xml performance_tips.xml.po >
 po2xml ../../postgis.xml postgis.xml.po > postgis.xml
 po2xml ../../reference_accessor.xml reference_accessor.xml.po >
 po2xml ../../reference_constructor.xml reference_constructor.xml.po >
 po2xml ../../reference_editor.xml reference_editor.xml.po >
 po2xml ../../reference_exception.xml reference_exception.xml.po >
 po2xml ../../reference_guc.xml reference_guc.xml.po > reference_guc.xml
 po2xml ../../reference_lrs.xml reference_lrs.xml.po > reference_lrs.xml
 po2xml ../../reference_management.xml reference_management.xml.po >
 po2xml ../../reference_measure.xml reference_measure.xml.po >
 po2xml ../../reference_sfcgal.xml reference_sfcgal.xml.po >
 po2xml ../../reference_misc.xml reference_misc.xml.po > reference_misc.xml
 po2xml ../../reference_operator.xml reference_operator.xml.po >
 po2xml ../../reference_output.xml reference_output.xml.po >
 found empty tag para
 po2xml ../../reference_processing.xml reference_processing.xml.po >
 po2xml ../../reference_raster.xml reference_raster.xml.po >
 po2xml ../../reference_temporal.xml reference_temporal.xml.po >
 po2xml ../../reference_transaction.xml reference_transaction.xml.po >
 po2xml ../../reference_type.xml reference_type.xml.po > reference_type.xml
 po2xml ../../reference.xml reference.xml.po > reference.xml
 po2xml ../../release_notes.xml release_notes.xml.po > release_notes.xml
 po2xml ../../reporting.xml reporting.xml.po > reporting.xml
 po2xml ../../using_postgis_app.xml using_postgis_app.xml.po >
 po2xml ../../using_postgis_dataman.xml using_postgis_dataman.xml.po >
 po2xml ../../using_raster_dataman.xml using_raster_dataman.xml.po >
 make[1]: *** No rule to make target 'xsl/postgis_aggs_mm.xml.xsl', needed
 by 'postgis_aggs_mm.xml'.  Stop.
 make[1]: Leaving directory
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3303>
