[postgis-tickets] [PostGIS] #1946: 'Spatial exception - geometry intersects edge 5' exception at adding 3 polygons
PostGIS trac at osgeo.org
Wed Sep 30 08:39:09 PDT 2015
polygons
  Reporter:  wimned    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.0.7
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by strk):
 Ok, after fixing the regression in trunk, this case also fails with
 2.2.0dev ... (see #3304).
 Handling of big tolerances is still an issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1946#comment:9>
