[postgis-tickets] [PostGIS] #3609: debbie crashing on PostgreSQL 9.6 builds
PostGIS trac at osgeo.org
Sat Aug 6 08:42:16 PDT 2016
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.3.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 I thought this was just a fluke, but its been happening for past couple of
 runs.  Given that winnie is doing okay and she builds for PostgreSQL
 9.6beta3, I'm suspecting its something in PostgreSQL 9.6 that changed
 recently since debbie builds against PostgreSQL 9.6 head.
 -- last fail is this
 https://debbie.postgis.net/job/PostGIS_Regress/4232/consoleFull
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE TYPE
 CREATE FUNCTION
 CREATE CAST
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE CAST
 CREATE CAST
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 psql:/var/lib/jenkins/workspace/postgis/branches/2.3/regress/00-regress-
 install/share/contrib/postgis/postgis.sql:5636: server closed the
 connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 install/share/contrib/postgis/postgis.sql:5636: connection to server was
 lost
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3609>
