[postgis-tickets] [PostGIS] #3610: Switch garden tests to utilize JSON (or JSONB) for log storage
PostGIS trac at osgeo.org
Sat Aug 6 09:44:33 PDT 2016
 Reporter:  robe                   |      Owner:  strk
     Type:  task                   |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 2.4.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Right now the garden tests store results as XML which is an optional
 install for postgres.  I often don't build my postgresql with xml. Also
 xml in general has less support now than json does.
 Since JSONB exists from PostgreSQL 9.3+ and JSON for 9.2+ and is always
 present, makes sense to switch to that at least for 2.4.  We can do 2.3
 too since we dropped support for 9.1 in 2.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3610>
