[postgis-tickets] r15043 - Remove search path on functions (slows down some functions) and no longer needed now we schema qualify all calls
Regina Obe lr at pcorp.us
Tue Aug 9 19:46:53 PDT 2016
Author: robe
Date: 2016-08-09 19:46:53 -0700 (Tue, 09 Aug 2016)
New Revision: 15043
   trunk/extensions/postgis/Makefile.in
closes #3611
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2016-08-08 21:08:32 UTC (rev 15042)
+++ trunk/extensions/postgis/Makefile.in	2016-08-10 02:46:53 UTC (rev 15043)
@@ -37,7 +37,7 @@
 all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
-sql/$(EXTENSION).sql: sql_bits/postgis.sql sql_bits/postgis_proc_set_search_path.sql sql_bits/postgis_comments.sql sql_bits/rtpostgis.sql sql_bits/spatial_ref_sys_config_dump.sql sql_bits/raster_comments.sql sql_bits/spatial_ref_sys.sql
+sql/$(EXTENSION).sql: sql_bits/postgis.sql sql_bits/postgis_comments.sql sql_bits/rtpostgis.sql sql_bits/spatial_ref_sys_config_dump.sql sql_bits/raster_comments.sql sql_bits/spatial_ref_sys.sql
 	mkdir -p sql
 	echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
 	cat $^ >> $@
@@ -70,10 +70,7 @@
 sql_bits/postgis_comments.sql: ../../doc/postgis_comments.sql
 	cp $< $@
-sql_bits/postgis_proc_set_search_path.sql: ../../postgis/postgis_proc_set_search_path.sql
-	cp $< $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
 sql_bits/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql
 	mkdir -p sql_bits
@@ -96,7 +93,7 @@
 	cp $< $@
 #postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
-sql_bits/postgis_extension_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/postgis_proc_set_search_path.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
+sql_bits/postgis_extension_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
 	cat $^ >> $@
