[postgis-tickets] [PostGIS] #3616: Pull changes to address standardizer from pagc repository
PostGIS trac at osgeo.org
Tue Aug 30 19:23:04 PDT 2016
  Reporter:  woodbri              |      Owner:  robe
      Type:  defect               |     Status:  closed
  Priority:  medium               |  Milestone:  PostGIS 2.3.0
 Component:  pagc_address_parser  |    Version:  2.2.x
Resolution:  fixed                |   Keywords:
Changes (by woodbri):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15049" 15049]:
 #!CommitTicketReference repository="" revision="15049"
 Adding some commandline options to test_main.c for debugging.
 Fixed a bug in tokenize.c to allow MIXED token to follow an AMPERS token
 in the rules.
 This should close #3616
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3616#comment:4>
