[postgis-tickets] [PostGIS] #3679: Invalid geometries: equal and disjoint?
PostGIS trac at osgeo.org
Thu Dec 8 19:20:47 PST 2016
 Reporter:  mwtoews  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.2
Component:  postgis  |    Version:  2.2.x
 Keywords:           |
 It seems that GEOS and JTS think that invalid geometries are disjoint. For
 example, GEOS 3.5.0 from shapely:
 {{{#!python
 from shapely import geos, wkt
 geos.geos_version_string  # 3.5.0-CAPI-1.9.0 r4084
 g = wkt.loads('LINESTRING(1 1, 1 1)')
 g.is_valid  # False, Too few points in geometry component at or near point
 1 1
 g.relate(g)   # FFFFFFFF2
 g.equals(g)   # False
 g.disjoint(g) # True
 And same from JTS. This is also the same behaviour of PostGIS up to
 version 2.1
 SELECT PostGIS_Version(), PostGIS_GEOS_Version(),
     ST_Relate(g, g), ST_Equals(g, g), ST_Disjoint(g, g)
 FROM (SELECT 'LINESTRING(1 1,1 1)'::geometry g) g;
 -[ RECORD 1 ]--------+--------------------------------------
 postgis_version      | 2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
 postgis_geos_version | 3.4.2-CAPI-1.8.2 r3924
 st_relate            | FFFFFFFF2
 st_equals            | f
 st_disjoint          | t
 However, since PostGIS 2.2, the invalid geometry may also be equal:
 postgis_version      | 2.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
 postgis_geos_version | 3.5.0-CAPI-1.9.0 r4090
 st_equals            | t
 st_disjoint          | t
 Unless this change was intentional, I'd expect invalid geometries to
 always be disjoint, and never equal. Disjoint and equal are opposite, so
 it is surprising to see this result.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3679>
