[postgis-tickets] r15275 - Fully qualify performance test script
Sandro Santilli strk at kbt.io
Fri Dec 16 10:55:40 PST 2016
Author: strk
Date: 2016-12-16 10:55:39 -0800 (Fri, 16 Dec 2016)
New Revision: 15275
   trunk/topology/test/perf/TopoGeo_addLinestring.sql
... helps running it from single-mode postgres
Modified: trunk/topology/test/perf/TopoGeo_addLinestring.sql
--- trunk/topology/test/perf/TopoGeo_addLinestring.sql	2016-12-10 09:33:42 UTC (rev 15274)
+++ trunk/topology/test/perf/TopoGeo_addLinestring.sql	2016-12-16 18:55:39 UTC (rev 15275)
@@ -1,8 +1,8 @@
-SELECT DropTopology('topoperf');
-SELECT CreateTopology('topoperf');
+SELECT topology.DropTopology('topoperf');
+SELECT topology.CreateTopology('topoperf');
 \timing
 SELECT count(*) FROM (
-  SELECT TopoGeo_addLinestring('topoperf', g) FROM (
+  SELECT topology.TopoGeo_addLinestring('topoperf', g) FROM (
     SELECT ST_ExteriorRing(ST_Buffer(ST_MakePoint(x, y), 10, 10)) g FROM
       generate_series(-15,15,5) x,
       generate_series(-15,15,5) y
