[postgis-tickets] [PostGIS] #3426: Patch to fix test_wkb_out_point failure on hppa & mips.
PostGIS trac at osgeo.org
Wed Jan 13 10:15:51 PST 2016
  Reporter:  sebastic  |      Owner:  robe
      Type:  defect    |     Status:  reopened
  Priority:  medium    |  Milestone:  PostGIS 2.2.2
 Component:  postgis   |    Version:  2.2.x
Resolution:            |   Keywords:
Comment (by strk):
 Example hard-coded values (FOSS4G FOSS4G):
 -- XDR:
 select ST_AsText(decode('0101000000F05546F05546f87fF05546F05546f87f',
 'hex')::geometry);
 -- NDR:
 select ST_AsText(decode('00000000017FF7F05546F055467FF7F05546F05546',
 'hex')::geometry);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3426#comment:13>
