[postgis-tickets] [PostGIS] #3423: CREATE EXTENSION postgis fails with "ERROR: could not load library "/usr/pgsql-9.5/lib/postgis-2.2.so": /usr/pgsql-9.5/lib/postgis-2.2.so: undefined symbol: GEOSClipByRect"
PostGIS trac at osgeo.org
Thu Jan 14 01:58:02 PST 2016
  Reporter:  motiumansky  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.2.2
 Component:  postgis      |    Version:  2.2.x
Resolution:               |   Keywords:
Comment (by motiumansky):
 Replying to [comment:9 robe]:
 > I wasn't sure if you were talking about redhat stable upstream.  Also
 I'm not sure what the difference is between the ones I use:
 > Like this one
 > http://yum.postgresql.org/9.5/redhat/rhel-6-x86_64/pgdg-
 oraclelinux95-9.5-2.noarch.rpm
 > and the one you pointed at. They have different urls, so I wasn't sure
 if they are just copies of the same thing.
 I have reproduced the issue when installing with yum install from the
 internet.
 I think there is something wrong with the last version installation on
 Oracle Linux (or Red Hat).
 Has anyone succeeded to install the last version on Oracle Linux or Red
 Hat?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3423#comment:10>
