[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
PostGIS trac at osgeo.org
Thu Jan 14 10:30:37 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS 2.2.2
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 I suspect it may have to do with conflicting symbols of the internal
 raster library statically linked in the two raster modules (from old and
 new extension) -- I will try tomorrow by building with --no-export or
 whatever it was that fixed the liblwgeom occurrence of similar case
 (symptoms do look like those ones: big dragons)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:7>
