[postgis-tickets] [PostGIS] #3428: Feature request: A function to convert a geometry's coordinates into a MultiPoint
PostGIS trac at osgeo.org
Thu Jan 14 23:33:18 PST 2016
MultiPoint
  Reporter:  mwtoews      |      Owner:  dbaston
      Type:  enhancement  |     Status:  assigned
  Priority:  medium       |  Milestone:  PostGIS 2.3.0
 Component:  postgis      |    Version:  trunk
Resolution:               |   Keywords:
Comment (by strk):
 +1 for sharing utility code
 See also the ASSERT macros with no CU_ prefix in cu_tester.h,
 which you may want to use inside the transformation_test
 (they add printing the obtained result when it doesn't match expected)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3428#comment:9>
