[postgis-tickets] [PostGIS] #3438: Unable to add NetCDF support to PostGIS 2.2
PostGIS trac at osgeo.org
Wed Jan 20 04:18:07 PST 2016
 Reporter:  N3tMaster  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS GDAL
Component:  postgis    |    Version:  2.2.x
 Keywords:             |
 I installed, into Ubuntu 14.10, Postgresql 9.4 with PostGIS 2.2 with Proj
 and GDAL support but I'm able to add NetCDF support to PostGIS.
 My Install steps were:
 1) installed postgresql 9.4 using apt-get
 2) installed proj, libxml by apt-get
 3) installed from source: hdf5, netCDF and GDAL 2.0
 4) installed from source: postgis 2.2.1
 I successfully check postgis version using SELECT postgis_full_version();
 command
 I enabled all gdal drivers with : SET postgis.gdal_enabled_drivers =
 'ENABLE_ALL';
 I enabled outdb gdal with : SET postgis.enable_outdb_rasters TO True
 I ran several postgis functions successfully
 but unfortunately when I launched select * from ST_GDALDrivers() NetCDF
 support didn't appear...
 moreover if I set gdal_enabled_drivers to "GMT" or "netCDF" , the query
 will run without error but the result of "st_gdaldrivers()" will be always
 0...
 I seems that Postgis recognizes netCDF/GMT code but I isn't able to find
 related driver information
 Any idea?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3438>
