[postgis-tickets] [PostGIS] #3439: [raster] inconsistent nodata values returned from multiband raster
PostGIS trac at osgeo.org
Wed Jan 20 13:02:03 PST 2016
 Reporter:  gdrolet                |      Owner:  dustymugs
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 2.2.2
Component:  raster                 |    Version:  trunk
 Keywords:  raster2pgsql ST_Value  |
 Inconsistent nodata values are returned when calling ST_Value on an out-db
 multiband raster:
 SELECT  gid,
         (ST_WorldToRasterCoord(rast, geom)).columnx x,
         (ST_WorldToRasterCoord(rast, geom)).rowy y,
         ST_Value(rast, 1, geom, FALSE) sd1,
         ST_Value(rast, 2, geom, FALSE) sd2,
         ST_Value(rast, 3, geom, FALSE) sd3,
         ST_Value(rast, 4, geom, FALSE) sd4,
         ST_Value(rast, 5, geom, FALSE) sd5,
         ST_Value(rast, 6, geom, FALSE) sd6
 FROM sg.raster_10x10_mult b
         INNER JOIN (
                 SELECT  gid, geom
                 FROM    sg.points
                 limit   10
         ) l
         ON ST_Intersects(rast, geom)
 ORDER BY gid;
 Pixels at locations with no data should all return -9999: bands 3 to 6
 return 0.
 SELECT  x band_number,
        (ST_BandMetadata(rast, x)).nodatavalue
 FROM   sg.raster_10x10_mult,(
          SELECT generate_series(1, 6) x
        ) foo
 WHERE  rid = 1;
  band_number | nodatavalue
            1 |       -9999
            2 |       -9999
            3 |       -9999
            4 |       -9999
            5 |       -9999
            6 |       -9999
 (6 rows)
 Raster sg.raster_10x10_mult was loaded using:
 raster2pgsql -s 3175 -p -R -P -F -e -Y -t 10x10 BLD_all_M.tif
 sg.raster_10x10_mult | psql -U postgres -d testdb -h localhost
 > gdalinfo BLD_all_M.tif
 Driver: GTiff/GeoTIFF
 Files: BLD_all_M_1km.tif
 Size is 2659, 3240
 Coordinate System is:
 PROJCS["NAD83 / Great Lakes and St Lawrence Albers",
     GEOGCS["NAD83",
         DATUM["North_American_Datum_1983",
             SPHEROID["GRS 1980",6378137,298.2572221010002,
                 AUTHORITY["EPSG","7019"]],
             TOWGS84[0,0,0,0,0,0,0],
             AUTHORITY["EPSG","6269"]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4269"]],
     PROJECTION["Albers_Conic_Equal_Area"],
     PARAMETER["standard_parallel_1",42.122774],
     PARAMETER["standard_parallel_2",49.01518],
     PARAMETER["latitude_of_center",45.568977],
     PARAMETER["longitude_of_center",-83.248627],
     PARAMETER["false_easting",1000000],
     PARAMETER["false_northing",1000000],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","3175"]]
 Origin = (1188631.738954391100000,2982399.663283404900000)
 Pixel Size = (801.504881290890810,-801.504881290890810)
 Metadata:
   AREA_OR_POINT=Area
 Image Structure Metadata:
   INTERLEAVE=PIXEL
 Corner Coordinates:
 Upper Left  ( 1188631.739, 2982399.663) ( 79d42'32.91"W, 63d42'27.63"N)
 Lower Left  ( 1188631.739,  385523.848) ( 81d 2'40.85"W, 40d 0'56.80"N)
 Upper Right ( 3319833.218, 2982399.663) ( 43d19'55.20"W, 58d11'52.36"N)
 Lower Right ( 3319833.218,  385523.848) ( 57d 6' 1.42"W, 36d35'24.78"N)
 Center      ( 2254232.479, 1683961.756) ( 65d28'29.73"W, 50d27'54.43"N)
 Band 1 Block=2659x1 Type=Int16, ColorInterp=Gray
   NoData Value=-9999
 Band 2 Block=2659x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
 Band 3 Block=2659x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
 Band 4 Block=2659x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
 Band 5 Block=2659x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
 Band 6 Block=2659x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
 PostGIS version''':
 POSTGIS="2.3.0dev r14604" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1,
 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
 LIBJSON="0.12" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3439>
