[postgis-tickets] [PostGIS] #3440: PostGIS 2.0 is broken at least for PostgreSQL 9.0
PostGIS trac at osgeo.org
Sat Jan 23 11:31:58 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.0.8
Component:  postgis  |    Version:  2.0.x
 Keywords:           |
 Looks like the last change broke PostGIS 2.0. Debbie stopped at PostgreSQL
 9.0 (which is the first), so it might only be 9.0 that is broken since she
 stopped there.
 -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.5.1devw64/bin/geos-config
   GEOS version:         3.5.1
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-1.11w64/bin
 /gdal-config
   GDAL version:         1.11.4
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg9.0w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.0.23
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.3
   JSON-C support:       yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 Error log is as follows:
 http://debbie.postgis.net:8080/job/PostGIS_Regress/2993/console
 cu_in_wkt.c:370:87: note: (near initialization for
 ‘wkt_in_suite.pSetUpFunc’)
 gcc -g -O2  -Wall -Wmissing-prototypes
 -I/var/lib/jenkins/workspace/geos/rel-3.5.1devw64/include   -I.. -c -o
 cu_tester.o cu_tester.c
 /bin/bash ../../libtool --mode=link gcc -g -O2  -Wall -Wmissing-prototypes
 -I/var/lib/jenkins/workspace/geos/rel-3.5.1devw64/include   -o cu_tester
 cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o cu_misc.o cu_ptarray.o
 cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
 cu_stringbuffer.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
 cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_surface.o cu_out_x3d.o
 cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../liblwgeom.la -lcunit
 libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes
 .libs/cu_tester cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o
 cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_measures.o cu_node.o
 cu_libgeom.o cu_split.o cu_stringbuffer.o cu_homogenize.o cu_out_wkt.o
 cu_out_wkb.o cu_out_gml.o cu_out_kml.o cu_out_geojson.o cu_out_svg.o
 cu_surface.o cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o cu_tester.o
 ../.libs/liblwgeom.so -lcunit
 #gcc -o cu_tester cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o
 ../.libs/liblwgeom.a -lm -lcunit
 -L/var/lib/jenkins/workspace/geos/rel-3.5.1devw64/lib -lgeos_c
 Makefile:62: recipe for target 'check' failed
 make[2]: *** [check] Segmentation fault
 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.0/liblwgeom/cunit'
 Makefile:147: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.0/liblwgeom'
 GNUmakefile:14: recipe for target 'check' failed
 make: *** [check] Error 1
 Commit that triggered this appears to be:
  r14607
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3440>
