[postgis-tickets] r14995 - Do not declare sfcgal_suite_setup when not implemented
Sandro Santilli strk at kbt.io
Sat Jul 16 08:20:06 PDT 2016
Author: strk
Date: 2016-07-16 08:20:06 -0700 (Sat, 16 Jul 2016)
New Revision: 14995
   trunk/liblwgeom/cunit/cu_tester.c
Modified: trunk/liblwgeom/cunit/cu_tester.c
--- trunk/liblwgeom/cunit/cu_tester.c	2016-07-16 08:05:51 UTC (rev 14994)
+++ trunk/liblwgeom/cunit/cu_tester.c	2016-07-16 15:20:06 UTC (rev 14995)
@@ -57,7 +57,9 @@
 extern void twkb_out_suite_setup(void);
 extern void out_x3d_suite_setup(void);
 extern void ptarray_suite_setup(void);
+#if HAVE_SFCGAL
 extern void sfcgal_suite_setup(void);
+#endif
 extern void split_suite_setup(void);
 extern void stringbuffer_suite_setup(void);
 extern void tree_suite_setup(void);
